Options
04-24-2023 11:56 AM - edited 04-24-2023 11:58 AM
1 REPLY 1
Options
04-24-2023 11:58 AM
@Joycesun usually SIM card are non-refundable. However, with your situation, i think support likely can do something
Please open ticket with them by messaging them the order numbers:
