01-17-2023 02:00 AM
Will be gone for 1-2 year, what is the cheapest way to keep my number and rewards points?
My Account
Rewards
Service
01-17-2023 09:07 AM
Try to find somebody who would take over your account/plan for that period of time. Any other solution would cost you a little bit.
01-17-2023 04:07 AM
I was think if the OP was gone so long. No of the family and friends will call or remember the old number unless it was programmed on their contact.
All in all, it will just cost a price of a SIM when they return and inform friends and family of the new number.
But you are correct that they will loss their points.
01-17-2023 03:16 AM - edited 01-17-2023 03:17 AM
So you are suggesting that rather than setting up a few reminders and paying $45 - $$ rewards per year to save their phone #/account/$$ rewards account the OP should abandon it and get stuck with a points account, new number and buy a new Sim card?
Edit:
OK my bad....I see the OP has a points account.
01-17-2023 03:09 AM
It would be a hassle disabling AutoPay and restart payment every -90 days. It is easy switching to the $15 plan but if you are gone so long. I would suggest you close your account and get a new SIM card and new number when you return because no one call or text you while you are out of Canada.
01-17-2023 02:46 AM
Lol....there is a winking emoji following my post. 😁
Here's another money saving tip.....quick stock up on bottles of Sen. They are currently $5 off at $6.99. 😉🍷
01-17-2023 02:38 AM
@darlicious- I was going for easy, less hands on. I realize it means forgoing the $2 autopay 3 times a year. We don't know what other rewards the customer is getting to stretch out even more dollars either.
01-17-2023 02:30 AM - edited 01-17-2023 03:23 AM
My preferred method is $6 cheaper per year than the autopay option.😉🤑😀
Edit:
Oops....we're even steven. I missed the bit about points.
01-17-2023 02:21 AM - edited 01-17-2023 03:22 AM
By setting up some reminders on your calendar and alarm to ensure you do not miss reactivation deadline dates (89/90days) you can suspend your account for $45(3×$15)/year (350 - 360 days) or less $$ depending on your rewards. Of course if your plan amount is fully covered by rewards there is no point in suspending your account. Here are your options for suspending your service for up to 89/90 days, reactivating for 30 days and repeating the process.....if you can time it so that you reactivate some time in December you will qualify for the "more is merrier" holiday gifts. Here are your options.....
OK.....and I have discovered using the spoiler option on the toolbar and your clipboard at the same time don't play very well in the community's sandbox! I will have to go back to the old way of copying my own post. Lol....every option is it's own little surprise! 🎉🎁🎊🎈🤪
Edit:
Ignore all references to $$ rewards if you are on points. Anniversary points are unaffected by suspension but you will only earn "Get back" points for payments. Give back points only if you earned them in the previous month and have active service when they are added to accounts between about the 5th and the 7th of the following calendar month and referral points I haven't quite narrowed down exactly when they are added and how suspension would affect them.
01-17-2023 02:07 AM - edited 01-17-2023 02:13 AM
Change down to the $15 plan and then pay every 4 months. You'll "waste" a 30 days of paid service then it'll go into suspension for 90 days. But be certain to make that payment every like 115 days. You lose it all if you go over 120 days.
Adding - and turn off autopay.
