Deleted Sim Card recovery
Nada81
While out of country I downloaded an eSIM card, but was unable to get it to work.  So I deleted it thinking it would go back to my original SIM card, but it has deleted as well.  How do I fix this problem and regain my original SIM card and number?
1 REPLY 1
@Nada81
For you problem that you cannot use PM service after the trip, you likely just need to delete your overseas travel esim, or remove the physical travel sim.   And check the VPN screen and delete any VPN profile there
And for the Public Mobile "sim", was that an eeSIM?  For the PM eSIM, once it is deleted, it cannot be recovered.  BUT Luckily, you can get a replacement for FREE
To rebuy new eSIM for FREE, first, download the app on your new phone and login.  If you have problem with receiving 2FA code, click "Didn't Receive code" or "Resend code" and choose either Send email or Send voice message
Once logged in, Click Account from the bottom, then click Purchase SIM Card and select eSIM
Once it confirms your phone is eSIM compatible, click Pay $  and Install (the system will check and apply a $5 credit to bring the total price back to $0 at checkout), and follow the prompt to complete and purchase and install eSIM on your device
(in rare case that PM charges you for the replacement esim, you can submit a ticket with PM support and ask them for reimbursement)
https://www.publicmobile.ca/en/on/get-help/articles/get-a-sim-card
Existing eSIM users at Public Mobile who need a replacement can do so at no extra cost. When you request a new eSIM through the usual process, we automatically identify you as an existing eSIM user and waive the replacement fee. See below for steps on how to get your new eSIM.
