Are my community login credentials the same for my account and this question forum?
blueberries78
Hi, I can log into this PM Community with my user name and password, (that's why I'm able to post here) but I cannot log into my account to pay for my bill. The account login asks for my email and password. I'm positive I'm putting in all that information correctly but it's not working. Can anyone help?
@Tsawwassen wrote:
Most likely --- but to make sure check your profile settings ---
The Community and My account can never have the same credentials. An e-mail address can't be the Community username.
Tsawwassen
@blueberries78  they don’t have to be but it’s best to have them be the same , self serve and community are two different systems
@blueberries78
Your account and this Community are different and not connected.
You can have the same email/user ID and password for both system.
If you activated your SIM/account and used the same email. You can check click on your avatar on the top right then click on My Settings…this will show your email address then click on Forgot Password.
@blueberries78   no, they are different systems
Community: while email is used to registered, you login with your username
My Account, email address is used to login
Of course, you can use the same email address to register both  (but again, Community use username to login).  And it is advised to use the same email address as you can earn Community rewards that way.
darlicious
@blueberries78
You likely registered the same email for both accounts but your self serve account uses the email as the username while your community account uses your username. Are you the type to use the same password  on different accounts? Or do you make different passwords for each of your accounts?
You can check your community account profile settings for the email registered. Is it the same as the one you likely used for your self serve? Have you tried logging into your rewards account? It uses the same login credentials as your self serve account. You could just be making an error you are not noticing? A comma instead of a period? A one instead of an "I"? Or yahoo instead gmail?
Edit:
Try using secret/incognito mode.
