2 weeks ago
- last edited
2 weeks ago
Dunkman
I have used their phones in the past and they are great phones. It has been a long time since I ever used their phone and it was with another service provider.
Does anyone know if Xiaomi works well on the PM network? I know you can check the bans but with the dropped calls on the network with my current phone , which is a Pixel 7 and it is a phone that can be used on the network.
Xiaomi Mix Flip may launch internationally
https://m.gsmarena.com/xiaomi_mix_flip_may_be_available_globally-news-63139.php
2 weeks ago
I'm not sure if it helps, but I used a Xiaomi phone for 2 years with Telus Mobility. I manually enabled Volte and it worked great. PM theoretically should be the same as it uses very similar frequencies on 4G and uses the same frequencies on 5G.
2 weeks ago
Dropped calls is not just you and your phone, it is widespread issue affecting many people in different locations with even "approved" VOLTE phone. I am sure PM/Telus is aware of it but so far there was no acknowledgment and ETA on when it will be fixed.
2 weeks ago
No personal experience with Xiaomi phones. However, Xiaomi phones are not on the whitelist for VoLTE approved phones for Public mobile. Not sure how that would affect the voice calling/dropping issue that PM is experiencing these days.
2 weeks ago
Pixel 7 as well.
2 weeks ago
What is the model of your phone?
2 weeks ago
Interesting, my phone drop calls a lot as well....
