06-04-2024 04:11 AM
still like it was before at reduced speeds after data rubs out in canada correct
06-05-2024 12:08 PM
@philmac June 5, 2924, PM just made a $34 5G 50 GB plus unlimited reduced data plan available for change on renewal. This is in B.C.,; check your own province.
06-04-2024 08:49 AM
@philmac if you are in Quebec, you can still get a $34 5G 60GB plan with unlimited data at reduced speeds.
06-04-2024 06:33 AM
@philmac depends on the 5G plan you have or planing to get. If you have a Canada-US 5G plan, then no unlimited data. But if you have a Canada only 5G plan, then yes , it will come with unlimited 512kbos data
But if you are just planning to change plan, the current lineup of 5G plans are all Canada-US 5G plans and hence they don't have unlimited data
06-04-2024 04:28 AM - edited 06-04-2024 04:33 AM
Sorry, no unlimited data plans on the current PM plans. Once you use up your data...you either need to purchase Add-on data or connect to wifi.
5G plans are 50, 75 or 100gb of data.
