Bermuda data roaming
jRHe
Hi,
im travelling to Bermuda for a 3 months straight, and would like to stay connected. Which data plans do you offer that will meet this need?
no " international roaming plan" with PM.
you might see International Long distance calling, but that is for making calls to other countries from Canada and not a roaming plan
But how about travel esim or local data sim? would it be sufficient for your needs?
jRHe
What about the international roaming plan? Will that work?
slusagm
PM only has roaming in US and Mexico, not in Bermuda
sorry @jRHe
no roaming in Bermuda.  You have to use travel esim or local data sim
hairbag1
@jRHe
with Public Mobile you only have service in Canada or USA with an add-on or dual country plan. For use in Bermuda, you need a local sim or use local wifi and WhatsApp.
