Nov 22 2024
Andrer098
since iphone 11 IOS 18 update this morning, I cannot call or receive calls
hi @Andrer098
physical sim card? can you test on another phone if so
if you have esim, you have to ask PM support to help.  Please submit ticket as advised above
@Andrer098
try your PM sim in a different unlocked cellphone (if you have esim, that's not possible though). See if service works as expected in a different cellphone.
Andrer098
When we try calling it response that we do not have an active plan
Andrer098
Reset network, it rebooted automatically
Did not solve
Reconnected house wifi, works great
Have you reboot your phone yet?  Try first
then update Carrier Profile
if still does not work, also try Reset network settings
and if you have a physical sim card, test on another phone to confirm it is not a device problem
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
First reboot the phone.
then Reset Network Settings
