Any international data add-ons available?
Oblong5000
Hi,
I'm leaving Canada to go abroad for vacation and would like to know if there are any available data add-on plans for an active phone service. I'm browsing about the add-ons section and community threads but can't find anything like it.
Thanks
Oblong5000
I'll just get a SIM card instead when I get there then.
Thanks everyone!
Chalupa_Batman
Hello @Oblong5000
Public Mobile only works in Canada and the United States (with the purchase of roaming add on). You can not use your Public Mobile in any other country. If you wish to use cellular services while you’re in another country, you can look at https://www.airalo.com/ for affordable data plans and then download an app like Fongo and pick a local number to where you currently live. They do however charge for texting. TextNow is free calling and texting. You can use both of these VOIP programs via WiFi or on a data only SIM card.
@Oblong5000
You need to either purchase a local SIM or use WhatsApp or TextNow app on wifi for free calling and texting.
If you are out of Canada for more than 90 days. I would suggest you suspended your account for 88 days and subscribe your account so you can keep your old number.
hairbag1
@Oblong5000
where are you planning to travel to and for how long ?
TheSterlinger
Only international data for US. Click the link, scroll down and click Top Add-Ons to see the add-on. https://www.publicmobile.ca/en/on/plans#ALL
@Oblong5000  Only for the US anywheres else and your best to get local pre paid SIM card in your destination
