04-08-2015 11:16 AM - edited 01-04-2022 12:37 PM
I've got a Moto G (first gen), Android 5.0.2, and a Public Mobile plan without data. Ever since upgrading to Android Lollipop, I routinely get a notification saying "Sign into network", particularly when I turn off or disconnect from wifi. If I dismiss the notification, it will just show up again later.
Obviously this doesn't have a significant effect on my phone use, but it is annoying. I've tried a couple of things, including changing the APN (Access Point Names) to the settings recommended by Public. Does anyone have any ideas about this? Thanks in advance.
02-20-2025 08:15 PM
Where is that option?
10-29-2021 06:22 PM - edited 10-29-2021 06:30 PM
If you just recently tried to do a port request from Fido to PM when you activated your sim card and plan, maybe it didn't get done right or fully.
Edit
So your phone is still trying to logon to their network, since you probably bought your phone through Fido when you were with them.
10-29-2021 06:18 PM
@ROBOTMAN88 : Fido? Where? When? How? Startup? When you want to open a web page? Do you have data left? Are you out of data?
10-29-2021 06:13 PM
I keep getting the message on my phone sign into fido Network and I would like that message to go away it's annoying me.
09-21-2021 06:00 AM - edited 09-21-2021 09:49 PM
@welshman41 wrote:Click on use this network as is
In the case of open Wi-Fi network buy that requires some type of authentication before use, choosing to use the Wi-Fi netwotk as is isn't going to allow for a working internet connection. Phones can be set to not automatically connect to open Wi-Fi networks.
Cell phones also show this same sign into network message at Public Mobile.when a customer tries to use dat but has ran out of data to use.
09-21-2021 05:42 AM
09-20-2021 05:19 PM
This is probably an android setting, not caused by data. Try turning off "open network notifications" in Android settings.
https://9to5google.com/2017/09/01/how-to-disable-open-wi-fi-network-notification-android-basics/
09-20-2021 05:15 PM
@ROBOTMAN88 wrote:I keep getting on my phone the annoying message sign in to network.
do one thing Make sure your phone is off before removing your SIM card,
and take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and if still not fix it please you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck
09-20-2021 05:12 PM
07-06-2020 08:04 AM
@Aq1345 wrote:Sir I am using nokia1 and it continues pup up sign in network and two third party sites not working
This error message usually means that you're run out of mobile data. If you log into your account, do you have an data remaining in your plan?
07-06-2020 08:01 AM
05-30-2020 02:19 PM
Stop
05-28-2020 08:17 AM
@Beth-maithya wrote:Yes sign in
Were you adding a suggestion to the thread or were you having your own difficulties?
If the latter then did you read the posts in the thread and try/look for some of the ideas?
05-28-2020 05:16 AM
Yes sign in
04-05-2020 10:57 PM
@Gopinath wrote:Not working in network
Are you new to Public Mobile?
Is your account active?
Do you have data or have you used it all?
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
04-05-2020 10:54 PM
03-05-2020 09:10 AM
@Pradeepyadav wrote:Sign in network
Perhaps you're out of data. Check for mentions of data in your overview page under data & add-ons. If you don't see any mention of data then you've used it all.
03-05-2020 03:13 AM
Sign in network
10-25-2019 02:15 PM
@Cyber wrote:
Good thing to do if you do not have DATA per month.
Motorola may have introduced some bug in Lollipops.
10-25-2019 02:15 PM
Hai
10-10-2019 02:55 PM
@KG2 wrote:Turn off this notification
That can't be turned off. Only way to prevent that if on plan with no data is to turn off mobile data setting.
10-10-2019 12:22 PM
09-22-2019 12:15 PM
Btw this post was originally started in 2015!
09-22-2019 11:55 AM
If your phone won't let you adjust them, try adding a new one matching the info below exactly.
Usually you click on a + sign to add a new one.
09-22-2019 11:53 AM
Try adjusting your apm settings to this:
If Android, click:
Settings > More / More Networks / Wireless & Networks > Mobile/Cellular Networks > Access Point Names >
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
09-22-2019 11:50 AM
@smallflightless wrote:I've got a Moto G (first gen), Android 5.0.2, and a Public Mobile plan without data. Ever since upgrading to Android Lollipop, I routinely get a notification saying "Sign into network", particularly when I turn off or disconnect from wifi. If I dismiss the notification, it will just show up again later.
09-22-2019 11:48 AM
Hello thanks
08-12-2019 09:34 AM
Sing in to network xox
07-13-2019 05:51 AM
My phone is fixed
09-20-2018 01:36 PM
@AshKaye88 you might want to start your own thread for better visibility so that hopefully someone can suggest an answer.
