3 hours ago - last edited an hour ago by computergeek541
2 hours ago
@HDmech You would need to connect to AT&T in Alaska and use 4G/LTE instead of 5G. There is no T-Mobile there and 5G doesn't always work on AT&T.
2 hours ago
Alaska belongs to USA but maybe service is limited to 'continental USA only' which PM does not mention.
Did you try manually to connect to USA providers (AT&T and T-mobile)?
3 hours ago
@HDmech sorry to hear that you weren't able to call while on the US.
Did you have roaming turned on? Did you data work at all?
Sometimes people are able to use data with the Canada-US plan, but have hard time with calls.
Did you connect to T-Mobile or AT&T?
Also your phone must be VoLTE enabled that can work on PM list.
3 hours ago
Just wondering if Roaming was enabled?
If it was then you will manually connect to AT&T or T-Mobile network.
