01-27-2026 06:17 PM
After activation with esim have erro esim activation failed and only has SOS. Bought a new sim thinking this is just sim sim issue. After changing sim with physical sim. Still has SOS.
Don’t know what to do. CS never respond since yesterday.
01-31-2026 11:47 PM
Did you resolve the issue? My problem is very similar to yours but I’m just about to go into the store to order a physical sim. They said everything was activated on their end. Now I can’t even port out to another service provider because I don’t have sms data or calls. Rip
01-28-2026 07:54 AM
I have exact issue. SOS since Jan 26, 7pm until now no resolution.
Started with eSim and bought sim from Amazon thinking maybe just fixed if I change to physical sim but did not solved the issue.
Tried inserting the Physical sim to 3 different phones all the same with SOS.
CS responded to me last night from my message the night it started with SOS and CS raised a ticket to their technical team and was told to wait 24-48 hours response time and could be faster.
01-27-2026 10:27 PM - edited 01-27-2026 10:35 PM
Hi @CSA_PM
Could you please take a look into my case as well? I already created a ticket last Sunday/Monday
Currently I have no services (call, data, text) after activation. However I got an email from public mobile confirming that my activation is active and ready for use.
I took the non-working physical SIM card to a different phone S25 and no services with that phone as well. The phone says unprovisioned/unregistered SIM. Thank you for your attention
01-27-2026 07:16 PM
01-27-2026 06:39 PM
Hi
I sent you a private message to your created ticket.
01-27-2026 06:24 PM
I did move the simcard to 3 different phones still the same. IPhone 15, 15 Pro Max and 14 Pro Max.
01-27-2026 06:20 PM
CS_Agent are probably swamped with porting issue on the 50% off promo.
My guess is it may take longer than 2-3 days to straighten everything out.
01-27-2026 06:19 PM
hi @mkhol
I wonder if it is the phone. do you have another phone to test the physical sim card?
we are just customers, so, you really need PM agent to help with that. The support queue is long, it will take time, please reply his last message and ask
