02-11-2022 10:46 AM
Hi, I have already purchased add-on data twice today but I have not still any access to internet. It is certainly shown on my overview page. I am wondering how I can use my adds-on. Thank you
02-11-2022 02:06 PM
@Nassirnassiri wrote:Hi, I have already purchased add-on data twice today but I have not still any access to internet. It is certainly shown on my overview page. I am wondering how I can use my adds-on. Thank you
@Nassirnassiri - the addons to you use while you are in Canada will show up in your overview section if you successfully add them to your account.
This section here:
If you do not see the addon listed here, and the $'s are still sitting in your Available Funds area, then you need to go back and do the 2nd step in the purchase addons area - add the applicable addon to your account - no need to add more funds.
NOTE: your account must be in ACTIVE status to use addons. Just incase you are currently suspended and think an addon will give you service.
02-11-2022 01:29 PM
02-11-2022 12:40 PM
There is a 2 step process for add-ons then power off the phone and power back on. Check and see it that works.
02-11-2022 11:49 AM
Exactly which ones did you purchase? Some can only be used in USA.
02-11-2022 11:19 AM
If you went through proper steps on buying add-on (first add funds to your account then actually purchase add-on) AND you can see them on your account, try rebooting your phone.
If that does not activate your add-ons best to do is to contact agent while waiting for any other suggestion.:
Send a private message to the CSA by clicking https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
