Additional US Roaming Charges withdrawn
Rameshkonjier
On 28th Dec. when I was in US and wanted to extend my previous US roaming plan, I had requested a bundle of $20 for extension. I noticed the request was not materialized for quite a long time. Subsequently I opted for another bundle of $15 on same day, so that my phone could continue. I was under the impression that only one charge will be applied as I had one service during the time. However, now I notice that amount for both requests are deducted from my account. Appreciated if one amount is refunded for which no service was given.
Thank you
hycm53
@HALIMACS wrote:
@hycm53
That's only if the same US add-on is wanting to be purchased.
The wait can be avoided by CSA intervention.
Another flaw around here... 🙄
Yes, it is very confusing.
HALIMACS
@hycm53
@Rameshkonjier
No worries, just contact a CS_Agent by creating a ticket through SIMon Chatbot below or private message them on the envelope icon above.
They will help you out but be warned that it may take up to 30 days to process the refund.
HI @Rameshkonjier   open a ticket with PM support.  If it was really overcharged, they usually would refund without problem
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@Rameshkonjier @For any sort a refund you need support
Getting help from agent
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get
Or get help right here in the community
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
