PUK code needed
ZB94
Please I need my puk code, my kids locked my phone and PUK code needed.
@dust2dust
I meant the parents should lock the phone with Face ID or PIN. 😉
@BKNS27- Not that smart! If they can't remember the number they typed in when setting it up then.... 🙂
@ZB94
Kids are so smart these days and they accidentally playing around with your phone.
Did you disabled your phone have Face ID or PIN on your phone to prevent this from happening again?
ZB94
Thank for your reply, I sent a ticket to get PUK code.
Yummy
Find your PUK: https://www.publicmobile.ca/en/on/get-help/articles/where-to-find-your-puk
- SIM network PIN blocked. Enter SIM network PUK - is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
- SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI (dial *#06# to get it) and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
- PIN unlock key (PUK) is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
    If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
    Once the PUK is recovered and validated, you will be asked to choose a new PIN.
    Only Public Mobile's Customer Support Agents (CSA) can give you this type of code, which the device manufacturer cannot.
    Caution! If the PUK is entered incorrectly 10 times in a row, the SIM card becomes unusable.
@ZB94   what was the exact error?  If it is sim card PUK , then PM support can help
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
open a ticket with PM Support using this direct link:  https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
