Add-ons
M3C
I currently have 0 data left with my plans but have lots in my add ons. Will Public Mobile automatically activate this to keep data available for my use?
@M3C  your welcome !
M3C
@hTideGnow  Awesome, thanks!
M3C
@hTideGnow  thanks for the reply! Sounds good!
HI@M3C
Yes, you don't need to do anything.  PM will automatically use the data add-on  on your account
If that does not work, try reboot the phone
One common thing that stop it from working is people set a data limit on the phone, so make sure you didn't set that
Let us know if the data still does not work, not using your data add-on
@M3C  Yes it will kick in automatically no worries
add here how to check your add on usage
Check add-ons /mins /Data
