11-10-2021 09:33 AM - edited 01-06-2022 03:59 AM
I purchased the wrong addon but then corrected it with the correct add on to text and call from US but cannot send texts. You took both the 10.00 and 15.00 from my credit.
11-10-2021 01:13 PM - edited 11-10-2021 01:14 PM
You will have to contact customer support to remove the accidently purchased add on and credit your account by using the links already supplied or by clicking the chat bubble at the bottom right corner of your screen.
To clarify pm did not take the amounts charged to your card. They are not authorized to do this only you are....by confirming and submitting your top up payment and further confirming and submitting your purchase of the add on. Public mobile is only authorized to attempt a one time payment for your outstanding plan payment once per 30 days if you are registered for autopay.
Here is some info about US roaming add ons that should help you.....
- While you have to have an active plan to purchase and use US roaming add ons the type of plan you have does not affect the roaming add ons features.
- US roaming add ons start the moment you confirm and submit your purchase in your self serve account and expire 240 hours later (10 days×24 hours).
- You can pre-load the funds needed to purchase the add ons in your self serve account so you only have to log in, select the US roaming add on and then confirm and submit your purchase.
- Wait til late as possible to purchase since they are immediately valid so on free wifi at the destination airport or stopping shortly before the border at mcd's or timmy's to buy the add on while on free wifi.
- If you are staying longer than 10 days you must wait a minimum of 24 hours to purchase the same US roaming add on or contact the moderators to add it before the waiting period ends.
- If you have two US roaming add ons with a talk feature that overlap the talk feature basically gets disabled. Avoid this....but you will have to get one removed by a moderator to get your calling feature back if this happens.
- After purchase reboot your phone and manually select either at&t or T-mobile to get better reception. Some areas have better coverage by either provider so when travelling around the US you will be better served by choosing the provider with better signal strength by locale.
- You will recieve incoming texts without any US roaming add ons. Adding the fongo app and textnow app for use on wifi are good to use for a back up plan or you could call forward your pm phone # to your fongo # before you leave Canada and purchase just the US data roaming add on. Fongo also works on mobile data (1 min=0.5mb/100 min=50mb) so you could still recieve incoming pm texts, recieve incoming pm calls to your fongo #/app, outgoing calls from your fongo number and outgoing texts from textnow for free or small fee from fongo.
- All US roaming add ons have either unlimted text, talk or both. Only data has limits depending on your purchase 250mb/500mb/1gb. Once the data is consumed it will just stop you could then purchase different roaming add on, wait 24 hr to buy or contact the moderator to buy the same US roaming add on again. (* except talk as previously mentioned.)
Happy travels and Stay--Safe!
11-10-2021 11:26 AM
sign in to Self-Serve, to review your account, if you found at Available Funds: $$
Try To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
- Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
- Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
- When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
- You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
- If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
- Select ‘Confirm my purchase’, and you’re off to the races!
after you Add-on you have to do Rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link.
if you purchased the wrong Add-on you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started. Type,, Ticket ,, Click ,, Contact Us ,, Select your issue ,,
Click here to submit a ticket↗↗.
- or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
- please include in your message,
- phone number,
- account number,
- account 4 digit pin,
- Email address,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
- During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
Good Luck...
11-10-2021 10:09 AM
Which two add ons did you exactly purchase? If you purchase add ons which overlap with service (ie. talk and text, text only), sometimes that causes a glitch in the system. You would need customer service agent to remove one of the add ons and then hopefully credit your available balance.
11-10-2021 09:59 AM
PM may likely credit your Available Balance for use towards future renewal or other services.
I doubt they would credit back the credit card.
11-10-2021 09:56 AM - edited 11-10-2021 09:57 AM
@debcase wrote:I purchased the wrong addon but then corrected it with the correct add on to text and call from US but cannot send texts. You took both the 10.00 and 15.00 from my credit.
If you explained your situation to CS nicely, I'm pretty sure they would credit you for the wrong purchase:
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
11-10-2021 09:39 AM - edited 11-10-2021 09:40 AM
Submit a ticket to a CSA. PM is prepaid so usually there are no refunds but explain your situation.
Here’s when and how to contact our Customer Support Agents:
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
- Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
