3 weeks ago
I am sure this has been asked a thousand times (there should be a sticky somewhere!), do you maintain all your add-ons if you reply YES to a Public Mobile subscription offer? I know I keep my rewards.
3 weeks ago
That will be fine, since the new plan has all kinds of data to begin with. I was more concerned about the international long distance minutes that I have. Thank you.
3 weeks ago
HI @Anonymous
bonus data will still be there
but if you are moving to 5G plan, since 5G has unlimited data at 512 Mbps, those bonus data will became incompatible addon and cannot be used while you are on 5G plan. They are still in your account, and will become "compatible"addon and can be used again, if you go back to 4G plan one day
3 weeks ago
@Anonymous
@Anonymous wrote:I have some bonus data add-ons that I guess I will be losing if I switch to a 5G plan. I have a 1GB, a 2BG, and another 2GB bonus. I also have lots of international and US long distance minutes. Hopefully I get to keep them.
you'll keep them all.
3 weeks ago
3 weeks ago
HI @Anonymous plan and addon and rewards are separate, so changing to the new BF plan won't loss any addon or rewards
3 weeks ago
@Anonymous
which add-on in particular are you thinking of ?
3 weeks ago
@Anonymous
yes, you will keep your current addon and rewards disocunt even after a plan change
(but of course, newly purchased data has a 30 days expiration )
3 weeks ago - last edited 3 weeks ago
Yes, you do @Anonymous
However, bear in mind, if you're moving to a 5G plan, your data add-ons will be unusable as they only apply to plans under 5G.
