01-05-2019 01:24 PM - edited 01-05-2022 02:58 AM
I had my plan set up last month the clerk set me up accidentally on province wide calling which I wanted Canada wide. I had thought I had change it to Canada wide which new schedule started today. In which it didn’t. So I changed it to Canada wide and it charged me double. What can be done?
01-07-2019 06:28 PM
Srlawren@ thanks
01-07-2019 06:01 PM
@Jenna536 wrote:I hope they can help me as it was the same day as my new plan started 67.00 times 2 charged out all on the same day. I did message 2 days ago haven’t heard anything back.
@Jenna536 current time to response seems to be around 3 or more days, so please hang in there. They will get to you!
01-07-2019 01:35 PM
Thanks @NDesai!
01-07-2019 01:30 PM
@srlawren wrote:
@slash407 wrote:
@Dunkman wrote:Typically, when you change plans, you lost what is remaining of the allottment of your original plan. PM does not pro-rate plans.
Only the moderators can help adjust your billing. Generally, they are quite helpful, but no guarantees. Expect 2-3 day wait though.
Send a private message to moderator through the following link :
does PM make this easily noticeable, upon changing ur plan? i hope they do because i can see alot of people falling in this pratfall
@slash407 there is verbiage but it's not entirely clear. See here for an example image: https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Changing-plan/m-p/311133/highlight/true... Basically, it tells you that your plan features will be lost. It's not very clear. I know the oracles have raised this up to @Alan_K and I believe his team are working on making this more apparent. Alan, the wording probably needs changing too, given that it's talking about plan features. I don't think it's clear as-is. cc: @NDesai @Luddite @ShawnC13 @will13am
It has been submitted. Expect that to take affect within a next few weeks.
01-07-2019 09:30 AM
01-07-2019 01:32 AM
01-06-2019 08:32 PM
Thanks so much.
01-05-2019 01:26 PM
