07-28-2022 05:04 PM
I tried to increase the number of In-Canada minutes from a current number of 100 to 500 by purchasing an Add-On. My credit card was charged but the number of minutes shown on my account is still 100. Why?
Add-Ons
08-08-2022 12:16 PM
@rgevans14 wrote:Thanks, I was finally able to get it to work. Is the add-on only active for one month or does it renew every month until cancelled?
@rgevans14 Add-ons are one time charges not "monthly". They remain on your account until completely used up.
08-05-2022 01:35 PM
07-28-2022 06:26 PM
Log in to your account...click on Plan & Add-ons...look on right side and you'll see a circular percentage counter with "500 min Canada-wide Long Distance "...it'll show you how much you started with and how many minutes are remaining.
07-28-2022 06:26 PM
rebooting device,and call *611 to check it out the minutes right ,, or use browser from computer, clear cache and cookies and use one page inPrivate mode, and Login Page
07-28-2022 06:25 PM
@esjliv wrote:@rgevans14 - were you doing this in your self serve account?
Purchasing an addon is TWO STEPS; be sure to:
- Add funds to your account, if you don’t have sufficient funds
- Go back to the Add-Ons page and select your Add-On.
If you still see the $s in your Available Funds area, then you need to go back to complete step #2.
Edit, the Canada wide calling for $5 will show as a separate line item in your addon section. Not added to your plan minutes.
The process is no longer two steps. As of July 13, any necessary payments will be done at the same time as selecting the add-on for purchase.
07-28-2022 05:07 PM - edited 07-28-2022 05:08 PM
