Add Ons
05-08-2020 07:18 PM - edited 01-05-2022 10:42 AM
05-11-2020 10:18 PM
im also on the 15$ plan. i added 5$ addon for 500 extra mins as a buffer in case i use up all the mins on my main 15$ plan. good thing about that add-on (and all add-ons offered by PM) is that it never expires. im on my 2nd month now with PM and i still have the add-on in place.
05-08-2020 10:48 PM
I agree. To be honest I did not even remember that the regular price for 1GB add on was $30 ir even that it was half off. I really only found that out here that the add on was on sale. Also with the previous thread that I think is now in the Lounger about having 20% off vouchers and $5 sim cards that they dont have anymore at Canadian Celluar supplier.
05-08-2020 09:04 PM
@tommygun1208 wrote:My $15 plan notified me that I had only 10 min. left so I changed my plan to the $25 one. When I went to use it, my phone said I could not make a local call because I did not have a long distance add on.....WTF?
@tommygun1208 anytime you face a situation like that sometimes it is good to come to the community and ask, "Hey I ran out of minutes whats my best option." It's a good idea to lean on the community some people may have some advice that we haven't thought to or a cheaper way to get a SIM card or extra minutes etc.
Stay safe brother!
05-08-2020 07:39 PM
You also have the option of just a calling add-on 500 minutes of Canada wide calling for $5. Any unused add-on minuted left at renewal will roll over until you use them up. Good augment for your $15 plan.
I would have to agree with @hairbag1 here that you could have just purchased the 500 mins add-on to tide you over until your renewal cycle, unless you do more that 600+ mins of outgoing calls per cycle.
05-08-2020 07:37 PM - edited 05-08-2020 07:38 PM
05-08-2020 07:31 PM
05-08-2020 07:27 PM - edited 05-08-2020 07:29 PM
You must choose between Change plan now or Change at my next renewal.
If you chose the first one, it should take effect...immediately.
05-08-2020 07:21 PM - edited 05-08-2020 07:22 PM
@tommygun1208 goto your self serve and check if you have "available funds" if you do, that means you still have to choose the plan and apply it.
05-08-2020 07:21 PM
@tommygun1208 restart your phone. And try dialing the number with a 1 in front of it. Welcome to the community. Stay safe. Stay off of the fudge.
05-08-2020 07:20 PM - edited 05-08-2020 07:21 PM
@tommygun1208 is it possible your plan didn't change check in your self serve
