07-21-2023 06:05 PM
Hi, I bought a Public Mobile SIM card and tried to activate it but the activation failed. I was able to pay for a plan, but when I opened the app to finish my activation, it said "Subscription not activated."
I've contacted Koodo support and Public Mobile support but no one seems to be able to help.
Is there a Customer Service Agent who can help reset my activation request so I can try again? I would like to start the process from the beginning.
07-21-2023 06:22 PM
Do you see a charge on your statement for the first payment that you've completed already?
This is what happens when using the Website, I caution everyone about that and recommend that you use the Mobile App for Activations (Beginning to End.) For a very smooth process.
07-21-2023 06:18 PM
Thanks, I will try to contact them and see if they can help.
07-21-2023 06:09 PM
@FredPoon- You should check your credit card to see if the payment went through. If the payment has already gone through, you do not want (and probably wont be able) to re-activate.
07-21-2023 06:09 PM
@FredPoon yes , please engage support by messaging them directly
