Cannot activate
12-22-2024
12:14 PM
12-22-2024
10:07 PM
computergeek541
In the app's activation page (step 6), the only two options I have are: "log out", and "get support".
How do I activate again?
Joining Public
12-22-2024 12:21 PM
delete the app from your cell...then get a new one and start over.
12-22-2024 12:21 PM
on iOS you will not be able to clear cache so I would reach out to a support agent, they should be able to get you to the finish line. Use one of the links that have been posted already
12-22-2024 12:19 PM
yes it is on the IOS app, log out and log in again does nothing, it shows the same page
12-22-2024 12:19 PM
@terrence13 If you been using the app and already paid get support to help finish the activation for you
12-22-2024 12:16 PM
@terrence13 have you been trying the the website or the app installed on your phone? To to the final activation it must be through the Public Mobile app. If it's still not letting you complete, trying logging out of the app and logging back in, you can also try clearing the app's cache/data and going back in. If still no luck reach out to a support agent for assistance.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
