Credit Card.
Priority
When Activating I had no choice but to use a Credit Card for Payment, however now that the account has been created I have no intentions of using the Registered Card any longer, I'm going to use Vouchers and only Vouchers for this Account.
How do I go about removing the registered Cresit Card in Payment Section? It doesn't let me remove it, only the option to Update and I want to remove it..
2 REPLIES 2
abtest
@Priority- Once you set the subscription to off (as I see in the image), your card will not be used for automatic payments.  That said, if you want it permanently removed from your account, then you must contact a CS agent as mentioned by @LitlLdy .
LitlLdy
@Priority , the only way to remove it is to send a private message to CS_Agents & ask for it to be removed. We haven’t been able to remove it ourselves for quite some time.
Or you can replace it with a prepaid card with $0 balance!
Edit: To fix my typos!
