Activation Issue - Authentication code sent to number that isn't accessible?
DesireeShea
Hello
I have just signed up through the website for a phone plan. I paid for it through the website and selected the e-sim option. It then prompted me to download the app to complete the plan (and e-sim) activation. The app sends an authentication code to my email... which I input, and then it says to input another code that is sent to a random phone number. I'm assuming I may have been been assigned a number... but obviously I can't access it. What a ridiculous oversight that prohibits new customers from signing up. Does any one have any solutions?
Thanks
2 REPLIES 2
@DesireeShea
Try these workarounds, it could bypass the SMS and open up the Send email option so you can get the code via email
  1. Reset your password to self service account. Once reset, sign in again with new password. Might be able to receive 2FA via email instead to gain access.
    (!!!You will need to click Resend Code and then Send email to trigger the 2FA to email)
  2. Potential workaround (for some): If you don't have access to SMS OTP, try entering an incorrect OTP code 4 times. For some individuals, this is giving the option of an email instead.
If none of those workarounds helps, please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
@DesireeShea  Contact support and cross your fingers that they can even help . Best of luck
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send  a  private message   To CS_Agents
