06-20-2022 11:06 AM
How I can change the Sim card after I lost my phone and my email
06-20-2022 12:30 PM
HI @katiahussein You don't even have access to your email?
If so, you want to create a new email address first. Then open ticket with CS Agent and ask them to help changing My Account to link up to the new email address
Once this is done, you can do Change SIM card as advised above
To open ticket with PM to change email address tied with your My Account:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
06-20-2022 12:00 PM
The change sim requires either a working email inbox or a phone. I assume you mean your email is no longer accessible ie. no longer subscribed.
Otherwise your email should be accessible via webmail. Then you can do this all yourself in the account under change sim.
06-20-2022 11:24 AM
If you have access to your account, get new SIM and change it through account
If you have NO access to your account and account is not deactivated/closed contact agent for assistance.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
06-20-2022 11:09 AM
@katiahussein hi if you lost access to your account they can help with both your issues
you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
