LOCKED OUT OF ACCOUNT
Tee1
  • I cannot remember my sign in and have now been locked out of my account. I tried resetting my password before this and cannot remember my security answer. I tried to submit a ticket but there asking for account # and pin things I don't have, please help!
@aru1 wrote:
how to find my Account
HI @aru1
What are you trying to do ?
My Account is here: https://selfserve.publicmobile.ca/
If you cannot login , forgot the username or password, you can open ticket with CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. First type: "Forgot log in information"
  2. Then Click "Contact Us"
  3. Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
aru1
@Tee1
If you cannot remember your security question, you will need CSA help.
See the 2nd method in the below link if you are unable to submit your ticket via SIMon Chatbot.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
HALIMACS
@Tee1
Make contact with Public Mobile Customer Support using option #2.
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
