06-20-2022 11:24 AM
I have my passwords saved, and I keep them written down so forgetting isn’t what happened, it simply tells me the information is wrong, this has happened before and I had to change my password even though the information I was using was in fact correct. Now it’s happened again, except this time it’s still telling me my information is wrong after just changing it - I also changed it before getting locked out since it happened before. Though now after changing I was locked out yesterday at 11:30 am and I am STILL locked out going on 24 hours later now. So I can’t even reset again, despite the fact that I shouldn’t have to, not sure why the login isn’t working but this is ridiculous.
06-20-2022 11:37 AM
I’ve been locked out for 24 hours now at this point, I did use the contact agent info though, thank you!
06-20-2022 11:34 AM
HI @annoyed2022 you can wait an hour and try again
If fails, try to reset the password with the Forgot Password link there
If still unable to login, open ticket with PM CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
06-20-2022 11:27 AM
@annoyed2022 hi yes it can get a little ridiculous sometimes if you tried all that
you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
06-20-2022 11:25 AM
Did you try different browser? Incognito mode?
If nothing works you will have to contact agent to unlock your account.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
