06-13-2022 11:34 AM
I pay for 2 accounts (for me and my daughter). I can not remember my daughter account ID and password so I can change her plan.
06-20-2022 11:31 AM - edited 06-20-2022 11:33 AM
HI @vasiucosmin did you check the Community inbox? they do not reply via email but reply at the Community inbox
here is the link
Also, it has been a week. You will for sure need to open ticket again. They will usually close the ticket if no one reply within 24 hours
06-20-2022 11:29 AM
Hi, i'm still stuck. CS did not answer and I don't remember the account or the password.Thank you
06-14-2022 11:36 AM
HI @vasiucosmin try to click on "Create Account " in Selfserve site and see if you can create one. If you can , then an account wasn't created before.
If it said an account is there already, then open ticket with CS agent, they can reset it for you. Follow the steps from my post above
06-14-2022 11:34 AM
Hi, it was activated in store....but i remember that i create an account so I can add my credit card for payments. Or they did this in store also?
06-13-2022 12:00 PM
@vasiucosmin wrote:Hi, i did create one as I add my visa for monthly payments
@vasiucosmin - if you activated in-store, it is possible the Self Serve account was not created then or afterwards since you must set this up separately when a store agent does the activation for you.
When you activate online the Self Serve account is created during the activation of the SIM card.
So, by what methods was your daughter's SIM card activated?
06-13-2022 11:54 AM
Thank you
06-13-2022 11:45 AM
Hi @vasiucosmin Just open the ticket and wait for CS Agent to grant you back the access
Once you have the access , you can then go to make plan change.
Just a reminder, make sure you select the proper choice between Change plan now and Change in the next renewal date.
06-13-2022 11:43 AM
06-13-2022 11:37 AM
Have you ever created a self serve account before, if not you can register for one here:
06-13-2022 11:36 AM - edited 06-13-2022 11:36 AM
HI @vasiucosmin Yes, you would have used another email for your daughter account
Open ticket with CS agent and they can sort this out for you.
At : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
