Activate eSIM
Martin_Le21
I'm having problems activating my eSIM. My eSIM could not be activated and I was asked to ask for support. I initiated a number porting process from my previous carrier to Public Mobile. However, I received a notification saying the process was incomplete. I'd like to understand what went wrong and how we can reinitiate the porting process. Could anyone please help? Thank you
Martin_Le21
Thank you so much
Martin_Le21
Thank you so much
@Martin_Le21
for porting issue,  There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
For eSim setup, Did you get to the eSIM installation step?   Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
@Martin_Le21  I’ll send you the porting team number private message . They can re trigger the port request for you . Will also leave you with the direct link to CS Agents incase they are needed
send  a  private message   To CS_Agents
