02-25-2024 08:02 AM
Hello,
The current offer 75 gigs Canada-US Plan for $40.00
02-25-2024 10:51 AM
02-25-2024 10:48 AM
Yes I am on the $34.00 plan right now -- 5g plan
02-25-2024 10:39 AM
Which plan are you on presently? If it is less than $34/month, then you might have a chance to "upgrade" to the $34 plan via customer service agent. If it is more than $34/month, your chances are low to be granted a switch to plan that is meant for new activations.
The $40 plan is still a very nice promo plan itself. With your legacy rewards, it will lower the price even further.
02-25-2024 10:23 AM
Thank you, I will certainly try 🙂
M
02-25-2024 09:41 AM
@mixxim10 Yes it will work in the US just like here at home for calling texting and data
also yes your rewards will stay the same you will not lose those , no worries
the 50GB $34 plan is just for new activations and not existing customers , however some have confirmed getting this plan just by asking support
send a private message To CS_Agents
