Account
Ray131
I want to add some data to my plan how do I make a self serve account?
9 REPLIES 9
Maybe putting it out there may cause them to recall putting those two pieces of information on the online activation.
Thus, no CSA intervention would then be required.
Quigley
Either way, the OP will still need CSA assistance.    So what's the difference.
Thus the question, @Quigley
I'm kinda curious if the OP did or didn't activate in store.
Quigley
@HALIMACS
They probably had their activation done in a store , awhile ago and didn't get around to creating the self service account, when they got home.
It's been known to happen a lot.
HALIMACS
How and when did you complete your activation here,  @Ray131?
If online, you created a self serve account during that process.
It's the email address and password you entered.
hi @Ray131 open ticket with PM support and have them to open the My Accout for you
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
@Ray131
Use the Chat Bot Simon to get a service ticket started first.
The link is at the bottom of this page.
If you have trouble using the Chat Bot Simon, you can also send a private message to CS_Agent   for help too.
Ray131
How do I talk to one?
walker1
@Ray131
If you don't have an account yet, you'll have to get a Customer Support Agent to set one up for you.
