12-14-2024
05:37 PM
12-14-2024
10:03 PM
computergeek541
Hi! I believe I let my last account expire and have struggled to get my number ported for several days. PM is showing my current number as the one I wanted to port, but I’m not able to make calls or receive texts, or even use data. The temporary number given also doesn’t work! Any one know how to fix?
12-14-2024 06:18 PM
Looks like that your account was also not set up properly with a failed port.
You will need to contact customer service agent:
Send a ticket via the chatbot to customer service agent (CSA) via link:
If that does not work,
Send a private message to CSA through the following link :
12-14-2024 05:58 PM
Thanks for the note. It was Telus and I’ve also purchased a month.
12-14-2024 05:52 PM
Hello @hharlacher
If you would like to port out your public mobile number, the account MUST be active. You will need to purchase a months worth just to port. Unless it's to Koodo or Telus. I know it's a waste of money but it's what's needed.
