Account Number
Tires
To Whom It May Concern,
My phone number is xxx.xxx.xxxx.......I need my account # please.
Thanks,
Sean
Edited by SD08 to remove phone number.
@Tires wrote:
It's been too long.....dont have access to account overview....is there someone I can call?
There's no voice support here anymore.
Do you know the email address you used? Maybe way back in your email inbox? Then try the Forgot your password? link. And for that you'd need to know the answer to your personal question.
Failing all of that then you'd need to send a private message to the @Moderator_Team < Click this.
Tires
SD08
@Tires
Your account number is listed in the upper-right corner of your account overview page. It usually starts with a 1000000.
I've edited your message to remove your personal info, as this is a public forum.
Triguy
If you log into your self serve account - you can find your account# on the top right hand corner.  You may want to remove your phone# from your post.
My phone number is xxxxxxxxxx.......I need my account # please.
Thanks,
Sean
If you can log in to your self-serve then it's visible there.
