Accidentally changed phone number
Hebrew
I accidentally changed my phone number and I need the old one back. Is it possible?
Outdoorsman
@Hebrew hi I can't say for sure but you can
contact customer service and ask for it back
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
      https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
will13am
@Hebrew , there is a good chance that you can get it back.  Use the chatbot link at the bottom of the web page to initiate a support ticket.
Hi @Hebrew  depends if you got the number from PM originally.  If it was from PM or Koodo or Telus originally,  the likely YES.   Open ticket with PM CS agent and ask now
to open ticket with CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
