Access to old phone bills
07-06-2024
04:50 PM
07-06-2024
05:33 PM
computergeek541
Hi there,
I used to use Public Mobile as my provider, and now I need help accessing my old phone bills from May and June 2022.
Please help me with that. Thank you.
Ottavia N
Payment
07-06-2024 07:18 PM
Open chatbot, type 'ticket', follow prompts and eventually you will be offered to open a ticket.
TRY not to message agents directly as this might significantly delay their response and resolution.
07-06-2024 05:20 PM
Hello @ottavia
Public Mobile and their CS Agents can only go back one calendar year. Sadly you will not be able to access them past that point. The only option to go back farther is with a court order for any legal case.
07-06-2024 05:07 PM
HI @ottavia
try this link for message support agent:
07-06-2024 05:04 PM
@ottavia wrote:Hi Meow, Thank you for your response. I understand it's pretty much in the past so how can I open a ticket btw?
Thanks.
07-06-2024 05:01 PM
Thanks.
