Saturday
Hi my account is not working. My account has $26 inside and my plan is $20 however after the payment it says I have a balance but still says my service is suspended. I logged in online and it says to resume activation but when I click on the button it says error code (Error Code: XXX). Please help to get my phone working again
Saturday
Did you try rebooting your phone by powering off then back on and see if that works.
Saturday
we are just customers like you. Support usually reply within 4 hours, so check your community inbox
Saturday
Unfortunately no one here can help you directly as we are just customers here. If you have opened a ticket you will need to wait for a response and will take a few hours to a day for a response .
Saturday
If your subscription has been paid but system asks you to 'resume' service, use clean browser, computer and try that way.
Check your payment history and confirm subscription has BEEN paid/renewed.
Saturday
i opened a ticket as the above did not work. Please somebody reply and fix my phone asap
Saturday
can you try login again using Incognit/private/secret mode on your browser and try Reactivate again?
if that does not work, you can try using *611 or 1-855-4PUBLIC and try to activate there, but you will need your 4 digits code
if both failed, please submit a ticket with PM support agent and ask them to help
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
