A new 5G US-Mex plan
kb_mv
I don't recall seeing this earlier......
20 REPLIES 20
triciaa
When you click on it, it then says new activations only...
@Juchter  One trick is to buy the $30 plan immediately and then you should see the $35 MEX plan to change to using change in next renewal option
hi @Juchter login My Account and see if there is a $30 plan. available to you (it is possible even you have a $40 plan). If $30 is there, some people can change to it and the $35 plan will be unlocked
Juchter
As we both have the $40  Can/US  currently , it looks like the $45 is the best they will do .
cant even get the $40 one ,presumably because there would have to be a price increase to be eligible.
not going to do it.
@Juchter  If you check your account you should see at least one of the CAN/US/MEX plans I’m on $34 plan and see the $35-$45-$55 MEX plans just not the $29 MEX plan
Yes they are. All options may not be, but existing customers have access to the Mexico plans if the monthly spend of the new plan is more than their current plan.
Juchter
Black Friday Can./US/Mex rate not available to current subscribers.
qile
Thank you for clarifying, I will have a try on it.
No idea, but they either didn't understand your question or they're misinformed. It's on the BC plans page. And I'm in BC and I just changed to it without incident. If you're worried about it, sign up with a temporary number first to ensure you can get it up and running. Once it's activated do a number change and port in your current number.
qile
Then why an agent just sent me a message, saying I can not port a BC phone number to this plan...
Yes
Diouf
Is this plan available in BC? Can I port a BC phone number from other carrier to this plan?
Darren21
I'm upgrading my business line to this promo and most likely porting my wife and son to PM as it's a deal too good to pass up.
@will13am I use both my phones as hot spots when we travel in our trailer to stream Fire TV and use laptop.
@kb_mv wrote:
@will13am wrote:
This $29 plan is not available for me unfortunately.  It also comes with 10GB which is not nearly enough data.
@will13am Not available for me either and like you it isn't enough data but it is a good deal for someone.
It wasn't that long ago I was still on the old 2016 fall promo which had all of 4GB per 30 days.  I am addicted to lots of data, so I can't go back.
@kb_mv  Nice find things are really heating up wonder what might appear on black Friday itself 🙂
nice find @kb_mv
they really have plans for anyone with any budget now 🙂
will13am
slusagm
so, price is even lower now!!
can't believe we can have roaming plan less than $30
