05-06-2022 12:36 PM
My daughters phone suddenly won’t work called 611 says go to website. Can’t login to website to see what is wrong. Can’t reset password. Created this account to even posted for help.
05-06-2022 04:09 PM - edited 05-06-2022 04:10 PM
@pretz99 You said the link worked? Or you're still stuck? Try using another browser if you're still having problems. Chrome or Edge perhaps?
Edit: @dust2dust Yeah, I didn't see the reply either until just now.
05-06-2022 04:03 PM
HI @pretz99 Message PM support to open ticket then:
05-06-2022 03:50 PM
I did message using the link provided. Not sure if it a Mac Safari thing not letting me continue
05-06-2022 03:49 PM
@dabr : Thank you. Yes I saw that he got it after I typed. The link in JK8's earlier reply also works.
05-06-2022 03:45 PM - edited 05-06-2022 03:46 PM
@pretz99 I just tried the link and it opens to a message box that you can type your issue in and one of the CSA's will respond and ask you to verify the account. Response time is usually within the hour but can take longer sometimes. Keep an eye on the envelope icon top right for their message to you.
@dust2dust the link works..
05-06-2022 03:45 PM
Do you get a ugly red error when you click that link provided? If so then click on your diving board avatar and settings and preferences and private messages and then check on private messages.
05-06-2022 03:43 PM
Awesome. that link worked. Thank you
05-06-2022 03:42 PM
No 611 says go to website
Website says can't log you in
Ticket says I need to be login in
Private message page is not a message page it does nothing
05-06-2022 03:42 PM
@pretz99 Send a private message to CS_Agent using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
05-06-2022 03:40 PM
I can't. It is like no one works there
05-06-2022 03:39 PM - edited 05-06-2022 03:40 PM
@pretz99 If she is on the $10 plan, then that's been an issue for other renewing their service after the price hike came into effect on April, 20th. Are you able to purchase a voucher and load the funds by dialing 611 on her phone?
Once you've added the extra funds, then her account should reactivate. Otherwise you'll need to submit a ticket to customer support as advised earlier to gain access to her account and then manually add the $3 and click the Reactivate button and log out and reboot the phone.
05-06-2022 03:39 PM
Then the account hasn't been affected by the price hike yet. So something else is very wrong. Have you got in touch with the support people?
05-06-2022 03:39 PM
As for ticket. Can't do that either because the account is locked out, and it will not reset my password, and thus I can't get a help ticket
05-06-2022 03:38 PM
I would love to talk to an agent or message someone.....
BUT when I private message it takes me to a page that says private message. But you can't do anything on that page, nice.
05-06-2022 03:36 PM
I did call. It says I have a zero balance and next payment is May 26
05-06-2022 03:35 PM
no it doesn't ring and goes directly to voice mail
05-06-2022 03:34 PM
Yes she is on the 10ish can't remember if I could login would know , but the 1-855-4PUBLIC says she has a zero balance and next payment is May 26
05-06-2022 03:31 PM
@pretz99 What plan is your daughter on? There have been autopay failures for other customers who have been on the $10 which recently got an outrageous 30% ($3) price hike effective April 28th and in those instances topping up the account with an extra $3 allowed for those accounts to be reactivated.
05-06-2022 01:21 PM
@pretz99 wrote:My daughters phone suddenly won’t work called 611 says go to website. Can’t login to website to see what is wrong. Can’t reset password. Created this account to even posted for help.
Use another phone to call your daughter's phone number. If her phone number rings on the other end, some bad guy may had hijack her number. Quickly, call her bank and cc to stop all transactions before the bad guy clean out her accounts.
05-06-2022 01:07 PM
Hi @pretz99 Did you try calling 1-855-4PUBLIC and what does it say for your phone number?
Do you remember if today or last couple days is the plan renewal day? Maybe the Autopay failed and account suspended?
05-06-2022 12:46 PM
Did you somewhat recently deal with a possible credit card problem?
05-06-2022 12:42 PM
Contact a CS Agent:
Contact our Customer Support Agents:
05-06-2022 12:37 PM
If the usual avenues are not working for you, you can either ope ln a ticket through chatbot or private message CS_Agent
