5 G to for 4G call quality
canirolf1
Hello, Wondering if anybody else experience same issue? I switched from 5 G to for 4G not too long ago. My phone is the same  Samsung S23. Was alright with the calls under the 5 G plan , however now with the 4 G plan call quality suffer a lot. This is in Calgary. Will go back to 5g eventually. For my self 5G is too much for now. Noticed sometimes plan fee are same for 4 or 5G. Thanks , Regards
@DennyCrane technically you're not. Your phone may display a 5G icon, but the voice call is 100% VoLTE at this time.
https://productioncommunity.publicmobile.ca/t5/Get-Support/5G-overview/m-p/964047/highlight/true#M66...
@sheytoon I'm able to make phone calls on 5G (and stay connected to 5G during the call).
sheytoon
There's no voice capability on 5G at the moment. It uses 4G (VoLTE) anyway.
Phil_Adelphus
@canirolf1  Is there any chance that VoLTE became accidentally disabled?
DennyCrane
@canirolf1 It shouldn't make any difference. Regardless of your plan, you can still connect to the 3G, 4G, or 5G networks.
