07-13-2022 01:33 PM
07-13-2022 01:49 PM
Yeah I mean it's still over $35 a month. Who knows, guess we will find out.. Won't be making a change until then.
07-13-2022 01:45 PM
@JL9- That would need company confirmation but my guess would be not. 4G is a very different animal. Because then the 2gb would convert to 4G. They might frown on that benefit. All the other add-ons would change. Ah. As I write this...maybe. It still makes business sense to allow it. 3G or 4G >= $35.
07-13-2022 01:41 PM
So just to confirm if you have the unlimited 2GB bonus on a 35 3G plan you can keep the extra 2GB on a 41.25 4G plan or not so much?
07-13-2022 01:38 PM
Nobody was ever stopping you to travel overseas with your phone.
But if you expect PM to offer roaming services outside of this continent you are out of luck; it will not happen in near (and far) future.
07-13-2022 01:35 PM - edited 07-13-2022 01:35 PM
@rossputin , the 4G plans have nothing to do with roaming. At the moment, the only roaming country is USA, no change from before. Rewards remain available with plan change.
07-13-2022 01:35 PM
@rossputin hi there are no overseas plans with public, no if you switch to a 4g plan you will not lose any rewards
