4G LTE Plan - Does it keep the extra 2GB of Data
MatthewV
Hello Community,
I have just recently moved to Public Mobile about two weeks ago. I have the 3G network plan with a bonus of 2GB of data. My plan is the $45/month 5GB plus 2GB/of bonus data.
My question is, If I move to the 4G LTE plan does the bonus 2GB data get removed from my account?
MatthewV
Thank you for you help on this, I appreciate it.
@MatthewV I know they are offering it to new customers ask a cs agent if they will add it if you change your plan
1.  you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
MatthewV
Thank you for letting me know. Do you know if you can re-add the bonus data or is it a one time add for your account?
RossN
@MatthewV hi no if you change to a new 4g plan you will lose that bonus 2 gigs
