11-26-2022 02:05 PM
Changed my plan to the $40 15GB plan upon renewal and it's coming up as only 5GB on my dashboard. Is this an error on PublicMobiles side? Hopefully this isn't the case...
11-26-2022 02:55 PM
Public Mobile has web page cache issue so you might be looking at obsolete status. Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
11-26-2022 02:27 PM - edited 11-26-2022 02:33 PM
As suggested by @HALIMACS , Cancel Plan Change...the re-select the one you want. When it looks right, take a screen shot and save it..just in case you need it for proof later on.
11-26-2022 02:09 PM
@jGil189 hi you will see the plan change on the 21st once your plan renews
11-26-2022 02:08 PM - edited 11-26-2022 02:15 PM
