11-25-2022
02:28 PM
11-25-2022
04:12 PM
computergeek541
I'm on the 3 month plan. Current cycle is Sept.3-Dec.5, the plan includes 6GB of data for the cycle. My power was out for 4 days during Fiona, during that time I used a significant amount of my plan data. When the 2GB Fiona bonus data code was sent to me, I claimed it immediately. At the bottom of my profile it says 0/2GB Fiona bonus data. Today I reached my 6GB limit that I have previously never hit before and instead of that bonus data activating, I've now had to purchase an additional 1 GB to get me through.
So back to my original question, what did I actually activate with that promo code if the bonus data didn't kick in when my limit was reached? Pretty frustrating situation overall.
11-26-2022 02:24 PM
Hi @jghfx yes PM is usually very reasonable
Happy ending
And, you and your family were ok with Fiona?? All good now?
11-26-2022 02:16 PM - edited 11-26-2022 02:17 PM
To follow up, Public Mobile customer service made this right in a very timely manner when I reached out to them.
11-25-2022 03:58 PM
Hi @jghfx
this is how to open ticket wirh CS Agen:
at : https://publicmobile.ca/chatbot.
First type Contact CS Agent,
from the list of , choose "Other"
finally click the the blue link about submit a ticket
11-25-2022 03:37 PM
How do I connect a CSA?
11-25-2022 02:54 PM - edited 11-25-2022 02:55 PM
since your renewing your plan on Dec 5th. I suggest switching to the new promos $40/15gb and $45/20gb. schedule a plan change on your renewal date or since you're out of data you can change immediately. if you decide to change immediately add $40/45 to the account. the $40/15gb will expire tomorrow I'm not too sure about the $45/20gb
11-25-2022 02:46 PM - edited 11-25-2022 02:47 PM
@jghfx I see the edit now.. message csa…
11-25-2022 02:43 PM - edited 11-25-2022 02:44 PM
@jghfx Didn’t miss read.. what are you asking for?the 90 day thing probably caused the problem.. you didn’t check things out
11-25-2022 02:42 PM
I think you misread my post. My data only ran out today. I am on a 90 day plan.
11-25-2022 02:38 PM - edited 11-25-2022 02:40 PM
@jghfx What happened was terrible.. a bit late now to be asking for help….it was offered.. was a little late..when offered but it was offered
11-25-2022 02:34 PM
HI@jghfx Unfortunately the 2GB Fiona bonus has a 30 days expiry. Yes, in your case, it will drain your regular data before add-ons kick in, which is normal.
Maybe open a ticket with PM and explain the situation and hope they can give you a one time credit ?
Try
