3x points offer
LVJ
I activated a second phone for a family member. Will this plan qualify for the 3x points back?
LVJ
Thank you. I will try this.
HI @LVJ
you could ask PM agent to see if they can add the code back for you after the activation, it is possible
For the 3x points, open ticket and ask them if they are missed, but you should see a 1x entry first, then a 2x entry couple days later
To open ticket with PM CS agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
LVJ
Didn't use the code. The second phone is also in my name but is also a new activation. Plan says for new activations. I have not received the bonus points after 3 weeks.
HI @LVJ
yes, alll new activation will quality for 3x points for 12 months
and you used your own friend code for activation on the new account to save $10?
Yummy
You will have to check what plan says and is it special offer or not.
