Owning two public mobile cards
Oscarkiai
Does anyone have two phones with two separate public mobile cards? What has been your experience? Also, I'm curious: Do you get extra points for the additional card? Is it similar to referring a friend?
2 REPLIES 2
Chalupa_Batman
Hello @Oscarkiai
I see a "Solution" has already been chosen but I'm not sure that's the correct answer you were looking for.
Yes, I have a Public Mobile eSIM and another providers SIM card on one phone. I also have Telus eSIM on another phone along with my US physical SIM card. Most phones can handle multiple eSIMs.
I've had no problems switching back and forth. I just click on which number I wish to use to make calls and such.
If you wanted multiple phone numbers on your phone, then you can use your ORIGINAL phone line with Public Mobile and use THAT referral code. You would therefore get 1 point per each number. Each account would earn it's own points for whichever plan you choose.
Hope this helps.
funpig1
@Oscarkiai
If you use referral code of the first account for the second account, the first account will earn a referral reward point each month.
I have helped family members and friends open accounts.
