01-20-2023 07:23 PM
why does my plan say its on the 4G network but my cell says I am only getting 3G?
01-21-2023 12:13 PM
When there’s just more traffic on the network than it can reliably support, users may see full bars of signal but experience poor download speeds.
01-20-2023 07:34 PM
@Cyberman No worries we here to help
01-20-2023 07:33 PM
thanks for the info everyone, that helps...
01-20-2023 07:28 PM
@Cyberman Yes if you have 4G service but it can change depending on area coverage and environmental areas ie grocery store
01-20-2023 07:28 PM
Check your phone settings to be sure you're connections include LTE/4G. Maybe also you're in a poor 4G area.
01-20-2023 07:25 PM
so is my data speed on 4G?
01-20-2023 07:24 PM
@Cyberman You will see 3 g for voice even thou your on a 4 G plan
