$34/month 5G 20GB
Sharonzxy
Does this only apply to eSim? I hope it's can be on physical card.
Thanks
2 REPLIES 2
DennyCrane
@Sharonzxy Makes no difference whether you're using esim or physical sim. For any plan.
SourDude1234
Hi @Sharonzxy
You can use physical SIM Card with it.
