11-13-2023 02:52 PM - last edited on 11-14-2023 04:08 AM by Andu_S
11-13-2023 03:38 PM
I've sent a message to billing dept. Thanks for your help.
11-13-2023 03:19 PM
I did. Thanks.
11-13-2023 03:16 PM
First time post inquiry to public. Thank you for your comments. I did delete personal info.
11-13-2023 02:58 PM
@jqin1313 You should delete your personal information immediately to avoid getting targeted by scammers as you're posting on an open public forum to anyone with internet connection to view. Click the down arrow top right of your post and select edit to modify your post.
If you've changed to a 90 day payment plan, then the full rewards will only be available after completing the first 90 days cycle as far as I'm aware, however, you should be have received any rewards due for the past 30 day payment cycle.
11-13-2023 02:57 PM
Seriously @jqin1313 ? This is a public forum. You need to delete all that private info now!!
11-13-2023 02:57 PM - edited 11-13-2023 02:57 PM
Hello @jqin1313
First, check your payment history for any add-ons, etc. If there are none, please contact an agent using the following link. We are also customers so it is best not to share personal information unless you are talking to an agent.
Monitor the envelope icon on the top right to get the notifcation.
