03-09-2026 06:10 PM - edited 03-09-2026 06:12 PM
Hello, I'm currently on a $30 4G plan (CAN-USA) with 20GB of data. I see in my account that there is a $30 5G plan (CAN-USA-MEX) with 30GB of data. I know that 4G is more than enough speed at 100mbps and it depends on your location. My question is, if I switch to this new 5G plan, would the reception/coverage be better or maybe even worst? I find that sometimes my reception is spotty using 4G and internet is slow.
Any thoughts?
03-09-2026 07:41 PM
hi @turok_t
reception and coverage would be the same. Your have a 4G plan, it is 4G speed. it just means you can have a max speed of 100Mbps. And even you have a 4G plan, you will still turn on 5G on your phone and try using 5G network
03-09-2026 07:35 PM - edited 03-09-2026 11:25 PM
The plan names '4G' and '5G' are just names, they only affect the speed limit of the plan. The network you connect to is exactly the same, the same reception, the same coverage, even if you have a really old '3G' speed plan, you can connect to the 3G/4G and 5G network. Only the maximum speed you can obtain changes.
03-09-2026 06:14 PM
@turok_t It will be the same and worth changing to just make sure you use the change in renewal date and not immediately so you don’t lose money in your current cycle . You can still use the 4G setting in your phone or change it to 5G that part dosent matter except you have faster internet and more data for same price so it’s a win/win
